01-20-2005 08:51 PM - edited 03-02-2019 09:12 PM
There is something I don't understand in the Cammand Reference :
Under the Usage Guidelines, it says "A default metric is required to redistribute a protocol into IGRP or EIGRP, unless you use the redistribute command." I have looked under the redistribute command, but I cannot see a way to specify an EIGRP metric, only an OSPF one.
Am I reading the document wrong?
Kevin Dorrell
Luxembourg
01-20-2005 09:28 PM
Kevin,
Dont you see under the eigrp process -
(say redistributing OSPF to EIGRP)
redistribute ospf 100 metric B D R L M
01-21-2005 12:17 AM
Thanks. I should have tried it on a lab router; I'll do that next time I have access to one. I was working just from the doc.
In that case it is the doc entry for redistribute that confused me, because it only mentions the keyword metric for OSPF and a single metric, and not redistibution into EIGRP with its multiple metrics. I'll try and check it out for real this evening.
Thanks again.
Kevin Dorrell
Luxembourg
