Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Eigrp un-equal load balancing ratio 3 to 2 ????
We are distributing traffic load to 2 link with 3 - 2 ratio.
I can make it to 3 to 1 or 2 to 1 with variance .
but, can we do it with 3 to 2 ratio ?
any idea ?
thanks
Gold
Re: Eigrp un-equal load balancing ratio 3 to 2 ????
Variance only tells you which feasible successors to include in the routing table, the metrics on the routes determine the load share ratio. The way it's determined is to take the highest metric installed in the table, and then divide each lower metric to find the ratio.
I don't think you can get a 3 to 2 ratio unless you have something like this:
1200
600
400
Then you would get 1, 2, and 3. But there's no way to get 3 to 2 with just two links, the way the math is done.
Russ.W
Gold
By the way, we've had another couple of requests for this capability, so we might be filing it as a future feature request. It will probably take some time to get it into code, but I thought I'd let you know.
Russ.W
268
