Enabling multicast on Cisco 2950 EI switches with no router
I have an application that needs to use multicast in a computer lab area. I have decided to only enable multicast on two switches and block it from the rest of the network using the port storm control command on the 2950 EI switches. I have been doing some research and have been unable to find the command string for enabling multicast without a router. The only command that I can think to use is the "ip igmp snooping" command. There are no routers involved this will strictly be at layer 2, and only on 2 switches, so any help will be greatly appreciated.
Re: Enabling multicast on Cisco 2950 EI switches with no router
To constrain multicast traffic, you will still need a router or a switch capable to act as an IGMP querier.
The following page was written for 6500 but you should get an idea
http://www.cisco.com/warp/public/473/38.html
You can enter static mac table entries in the switches. Also, if you need enter in the router, you can use the static ARP entries.
374
