Webcast-Catalyst9k
Enabling RBE Bridging for DSL
Hi All,
I am enabling RBE bridging for DSL on a Cisco 7513 router. Here is my sample config that I've drafted for it, for an ATM subinterface. My question is pretty striaghtforward: should this config work? If not, any suggestions, feedback, would be appreciated. Just trying to get another set of eyes on this.
interface ATM10/0/0
no ip address
no ip directed-broadcast
no ip route-cache distributed
logging event subif-link-status
atm uni-version 3.1
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
atm arp-server self
interface ATM10/0/0.1 point-to-point
description DSL Network utilizing RBE
ip unnumbered Loopback1
no ip route-cache
ATM route-bridged ip
atm pvc 1 1 32 aal5snap 5500 4700 100
bridge-group 1
Thanks.
1 REPLY
Re: Enabling RBE Bridging for DSL
The config may not work,
You want to configure 7513 to terminate the DSL connection running RBE..Means 7513 will work as DSL aggregator for RBE connection, here is the sample config for that
http://www.cisco.com/warp/public/794/soho77rfc_6400rbe_1.html
Config is for 6400 but will be the same for 7513 too.
You need to enter a static route for a user's ip address (10.1.1.1 in sample config) if ip address are not allocated via dhcp server.
163
