Webcast-Catalyst9k
encapsulate Ethernet Frame over Ip
I Need Encapsulate Ethernet frames Over IP
I show you a brief diagram of our network:
Ethernet Machine <--> Router Cisco <--> Smart Switch Router (ip Ruting) <--> Router Cisco <--> Ethernet Machine.
Can I Use Ip-tunnel ?
can I Encapsulate Ethernet frames Over Ip?
1 REPLY
Re: encapsulate Ethernet Frame over Ip
Well, yes, I suppose that IP over IP tunneling would work, but I'm unclear what you're trying to accomplish here.
Is there some reason standard IP routing won't work? You might want to take a look at IP Mobile-arp, since I'm guessing the two ethernet devices are on the same IP network. However, I would not consider Mobile-arp a long-term solution.
310
