Community Member
encryption for remote access network
we have implemented a remote access network for our customer using AS5300s and cisco 3600 series routers with appropriate modem modules at different locations in the customer network. The current network has TACACS authentication.
We have to implement encryption on this network. Can anyone suggest how to go about it.
regds
kvrm
Re: encryption for remote access network
If you're intended to encrypt the traffic between remote hosts and corporate network I think what you need is a remote access VPN implementation. Some documents that may help:
An IPSec introduction:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a0080094203.shtml
An VPN introduction:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a0080094865.shtml
Configuration example for a remote access VPN scenario:
http://www.cisco.com/en/US/tech/tk583/tk642/technologies_configuration_example09186a00800a393b.shtml
Hope these help.
Regards.
Community Member
Thanks for your help on that. I'll go through the docs and revert for help if required.
83
