ErrDisable at SFP Interface between C3750 with C3560
Requirement: connecting 2 lan switches with SFP cable.
The LAN Switches to be connected are: C3560-24TS+2SFP with C3750-24TS+2SFP
Cable SFP: CAB-SFP-50CM-cable
when the installation is done, the error show up in the SFP interface, as below:
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/1                      err-disabled 1            auto   auto unknown
Test_Switch#sh interfaces status err-disabled
suspected err is from the cable, which is not working for both lan switch.
Port      Name               Status       Reason
Gi1/0/1                      err-disabled gbic-invalid
Question: what type of cabling is suitable/compatible to be used for connecting 2 different types of lan switches?
Run the errdisable recovery but not help much.
Thanks in advance.
Hira
1 ACCEPTED SOLUTION
Super Bronze
Re: ErrDisable at SFP Interface between C3750 with C3560
As I understand it, you can only use that cable with 3560s:
http://www9.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml#patch-cable
Quote 'The Catalyst 3560 switch supports the SFP module patch cable, a 1/2 meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560 switches in a cascaded configuration. '
Or https://supportforums.cisco.com/docs/DOC-1515/diff;jsessionid=0C72B9E367B58777F2C7AF045001E637.node0?secondVersionNumber=3
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Yap, you are correct. that cable can be only used for 3560s.
I want to order below SFP for connecting the C3560 with C3750:
Cisco Gigabit Ethernet SFP: Cisco 1000BASE-T SFP
Part Number: GLC-T SFP-GET3
Description: 1000BASE-T SFP Transceiver Module for Category 5 copper wire.
is that a correct SFP type?
Thanks again
Hira
Hall of Fame Super Gold
GBIC-invalid would probably means that you have a non-Cisco SFP.
1287
