Webcast-Catalyst9k
Errdisable issue
By default IOS switches enable errdisable for link-flap and I have had several instances where this has occurred. My concern is if this where to happen to a very mission critical port.
Is anyone aware of any issues that can occur by disabling errdisable for link-flap. Have you done this and/or would you recommend it?
1 REPLY
Re: Errdisable issue
I think it is fine. It should not create any problem
86
