Webcast-Catalyst9k
cox
Error 619 specified port is not connected
We have a 3640 with an NM-30DM and a NM-1CE1U
Since the router recently lost power unexpectedly many of our users when trying to dial the router using an analogue modem are unable to establish a connection and receive the following message:
Users dialling over ISDN are un-affected by this problem.
The config is as it was before the loss of power.
Any Ideas
Thanks in advance for your help.
Re: Error 619 specified port is not connected
As the problem is with analogue callers only, you might have an issue with your modem board.
Try the command: sh modem status
to check for any dead or locked modems.
Leo
cox
Thanks for the reply Leo, I've done as you said and below is the output from one of my modems.
Any Ideas as to what I should be looking for?
I should also point out that some analogue callers can connect some of the time which would indicate that some modems have problems.
Thanks again for your help.
sh modem operational-status 2/0
Modem (2/0) Operational Status:
Parameter #0 Disconnect Reason Info: (0xDF00)
Type (=6 ): Tx (host to line) data flushing - OK
Class (=31): Requested by host
Reason (=0 ): non-specific host disconnect
Parameter #1 Connect Protocol: LAP-M
Parameter #2 Compression: V.42bis both
Parameter #3 EC Retransmission Count: 0
Parameter #4 Self Test Error Count: 0
Parameter #5 Call Timer: 28 secs
Parameter #6 Total Retrains: 0
Parameter #7 Sq Value: 3
Parameter #8 Connected Standard: V.90
Parameter #9 TX,RX Bit Rate: 46666, 31200
Parameter #11 TX,RX Symbol Rate: 8000, 3429
Parameter #13 TX,RX Carrier Frequency: 0, 1959
Parameter #15 TX,RX Trellis Coding: 0, 16
Parameter #16 TX,RX Preemphasis Index: 26, 3
Parameter #17 TX,RX Constellation Shaping: Off, Off
Parameter #18 TX,RX Nonlinear Encoding: Off, Off
Parameter #19 TX,RX Precoding: Off, Off
Parameter #20 TX,RX Xmit Level Reduction: 0, 0 dBm
Parameter #21 Signal Noise Ratio: 37 dB
Parameter #22 Receive Level: -24 dBm
Parameter #23 Frequency Offset: 0 Hz
Parameter #24 Phase Jitter Frequency: 0 Hz
Parameter #25 Phase Jitter Level: 0 degrees
Parameter #26 Far End Echo Level: -33 dBm
Parameter #27 Phase Roll: 0 degrees
Parameter #28 Round Trip Delay: 13 msecs
Parameter #30 Characters transmitted, received: 43, 176
Parameter #32 General Portware Information: 26
Parameter #33 PPP/SLIP packets transmitted, received: 0, 0
Parameter #35 PPP/SLIP packets received (BAD/ABORTED): 0
Parameter #36 EC packets transmitted, received OK: 2, 2
Parameter #38 Moving Average of EC packets (Received BAD/ABORTED): 0
Parameter #39 Robbed Bit Signalling (RBS) pattern: 0
Parameter #40 Digital Pad: None, Digital Pad Compensation: Enabled
Parameter #42 SS7/COT Status: 0
Parameter #43 V110/PIAFS frames received bad: 0
Parameter #44 V110/PIAFS frames received good: 0
Parameter #45 V110/PIAFS frames transmitted: 0
Parameter #46 V110/PIAFS sync lost: 0
I found a URL for you about troubleshooting mica modems. Please check it to make sure that your modems are OK.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a0080094330.shtml
Leo
148
