Community Member
Error: diagSyncLCBusAsic[15]: bus interface asic not in sync!
We are getting this error whem booting Catalyst 6509 SUP2/MSFC2 running CatOS 7.6.1 + IOS 12.1(19)E.
2003 Dec 11 01:27:17 %SYS-5-MOD_OK:Module 1 is online
2003 Dec 11 01:27:21 %SYS-3-FAB_CHNGMODE:System switching mode is being changed to compact mode
2003 Dec 11 01:27:27 %SYS-4-NVLOG:SYNDIAGS:Module 1 detected Local Bus stall. So
urce: B/P. Status Register = 0xf01
We tried these:
1) SUP2 "Slot1" + SFM2 "Slot6" ==> No error
2) SUP2 "Slot1" + SFM2 "Slot6" + WS-X6548-RJ-45 "Slot2" ==> error
3) SUP2 "Slot1" + SFM2 "Slot6" + WS-X6548-RJ-45 "Slot3" ==> error
4) SUP2 "Slot1" + SFM2 "Slot6" + WS-X6548-RJ-45 "Slot7" ==> error
5) SUP2 "Slot1" + SFM2 "Slot6" + Different WS-X6548-RJ-45 "Slot2 or Slot3" ==> error
What can be the problem ?
Note: Here is what I have when issue sh logg:
Getting this error on the log:
08. 6/11/2003,05:35:22: supVersion:Nmp version 7.6(1)
09. 6/11/2003,05:37:30: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
10. 6/11/2003,12:10:59: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
11. 6/11/2003,12:15:46: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
12. 8/6/2003,15:17:40: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
13. 8/16/2003,02:59:17: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
14. 10/19/2003,05:58:32: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
15. 12/11/2003,01:15:35: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
16. 12/11/2003,01:27:27: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
17. 12/11/2003,03:20:22: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
18. 12/11/2003,03:31:05: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
19. 12/11/2003,03:34:08: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
20. 12/11/2003,03:43:54: SYNDIAGS:Module 1 detected Local Bus stall. Source: B/P. Status Register = 0xf01
b) Power off the Switch and removed all modules and put them back and still getting the same error
1 REPLY
Community Member
Re: Error: diagSyncLCBusAsic[15]: bus interface asic not in sync
%SYS-5-MOD_OK (x1): Module [dec] is online
Explanation: This message indicates that the module passed the diagnostic self-test
and is online. [dec] is the module number
221
