12-18-2001 04:50 PM - edited 03-01-2019 07:48 PM
I am new here and I don't know if I am in the right area but I have a question that may be answered by one of you (hope).
When I go into the c2600 and do a 'test int serial0/0' I get a timeout problem.. 0 pass 1 failed. Does anyone know what this mean?
I have a point to point T1 and verizon ppl said it may due to a timeout in the router. If that is the cause, can anyone suggest anything?
thanks,
Ko
12-18-2001 06:15 PM
This test seems to be a more reliable indication that something works when it passes than it is an indication that something doesn't work when it fails. I have seen interfaces that could be pinged and could route traffic just fine but still time out on the test (even when back-to-back in the same room). I wouldn't rely on this to troubleshoot with.
12-19-2001 06:26 PM
do you have a suggestion?
thanks in advance,
Ko
12-20-2001 12:28 AM
Ko,
This command doesn't test your line it's actually intended for
checkout at the factory.
see :
http://www.cisco.com/univercd/cc/td/doc/product/software/ssr83/rpc_r/47985.htm
Alain
