Error using Cisco View 5.3
I am useing Cisco Works 2000 4th Edition with solaris 7,
these days i found that i can't use cisco view
while i open cisco view , it pop me the notice
Please grant permission to launch Cisco View . Quit the browser and try again
i have the CD 1 reinstall but still can slove this problem,does anyone knows what happen and how can i slove it?
Thank you very much!
Re: Error using Cisco View 5.3
I have the same problem !!! but on HP-UX server. When I mark any cisco device to make a CiscoView I have to log into the CW2000 (http://server:1741/JSP/cmf/security/Autologin.jsp?URL=http://server:1741/CSCOnm/servlet/com.cisco.nm.cvw.servlet.CvServlet?device=device_name - and after succesfull login there is a popup window "Please grant permission to launch CiscoView. Quit browser and try again".
Last time I had a problem with cookie (it was always disabled even I checked accept cookie option). I had 1.3 java version and I decided to insall prevoius version (1.2.2.13) and everything works fine except CiscoView on Management Station. On any PC it works good.
any ideas ??
reagrds
Pawel
I try to install JRE 1.3.1 and 1.4.0 today...but the problem still is!
My CiscoWorks works well except CV5.3...so strange!
Have you installed CD One 4th Edition Patch 1? It can be found at:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one
Remove any previously installed Java Plug-ins on client workstation. After patch is installed on server, open up CiscoWorks. You will be prompted to install new plugin.
I have install the patch1...but now i have another question,how can i install make Netscape realize the JRE 1.3.1 plug-in?...
How can i set the NPX_PLUGIN_PATH , CLASSPATH and NPX_JRE_PATH values?...
Thanks~
I have the problem slove^_^~
After the JRE 1.3.1 install to the default location(/usr/j2se), you must add line
CLASSPATH=/usr/j2se
to the jpi.profile in the root diectory,then the java plug-in will work correctly^_^~
185
