Error while connecting with PRI instead of bri
Hi all
i hve attached the debug of ppp negotiation from our router,earlier it was on Isdn bri now we are in the verge of converting the bri into pri at our side so tht the persons from remote can get connected with PRI instead of BRI.
using the same uid/passwd but unable to get connected.wht may be the reason
Router#
Jan 3 17:03:43.016 Router: %LINK-3-UPDOWN: Interface Serial1/1:27, changed state to up
Jan 3 17:03:43.016 Router: Se1/1:27 PPP: Treating connection as a callin
Jan 3 17:03:43.016 Router: Se1/1:27 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
Jan 3 17:03:43.016 Router: Se1/1:27 LCP: State is Listen
Jan 3 17:03:43.552 Router: Se1/1:27 LCP: I CONFREQ [Listen] id 76 len 27
Jan 3 17:03:43.552 Router: Se1/1:27 LCP: MagicNumber 0x07B9E21D (0x050607B9E21D)
Jan 3 17:03:43.552 Router: Se1/1:27 LCP: MRRU 1524 (0x110405F4)
Jan 3 17:03:43.552 Router: Se1/1:27 LCP: EndpointDisc 1 ootyrallis (0x130D016F6F747972616C6C6973)
Jan 3 17:03:43.552 Router: Se1/1:27 LCP: O CONFREQ [Listen] id 36 len 14
Jan 3 17:03:43.556 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.556 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.556 Router: Se1/1:27 LCP: O CONFREJ [Listen] id 76 len 8
Jan 3 17:03:43.556 Router: Se1/1:27 LCP: MRRU 1524 (0x110405F4)
Jan 3 17:03:43.568 Router: Se1/1:27 LCP: I CONFNAK [REQsent] id 36 len 9
Jan 3 17:03:43.568 Router: Se1/1:27 LCP: AuthProto CHAP (0x0305C22305)
Jan 3 17:03:43.568 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 37 len 14
Jan 3 17:03:43.568 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.568 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.584 Router: Se1/1:27 LCP: I CONFNAK [REQsent] id 37 len 9
Jan 3 17:03:43.584 Router: Se1/1:27 LCP: AuthProto CHAP (0x0305C22305)
Jan 3 17:03:43.584 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 38 len 14
Jan 3 17:03:43.584 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.584 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.600 Router: Se1/1:27 LCP: I CONFNAK [REQsent] id 38 len 9
Jan 3 17:03:43.600 Router: Se1/1:27 LCP: AuthProto CHAP (0x0305C22305)
Jan 3 17:03:43.600 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 39 len 14
Jan 3 17:03:43.600 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.600 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.616 Router: Se1/1:27 LCP: I CONFNAK [REQsent] id 39 len 9
Jan 3 17:03:43.616 Router: Se1/1:27 LCP: AuthProto CHAP (0x0305C22305)
Jan 3 17:03:43.616 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 40 len 14
Jan 3 17:03:43.616 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.616 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.632 Router: Se1/1:27 LCP: I CONFNAK [REQsent] id 40 len 9
Jan 3 17:03:43.632 Router: Se1/1:27 LCP: AuthProto CHAP (0x0305C22305)
Jan 3 17:03:43.632 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 41 len 14
Jan 3 17:03:43.632 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.632 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.644 Router: Se1/1:27 LCP: I CONFREJ [REQsent] id 41 len 8
Jan 3 17:03:43.644 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.644 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 42 len 14
Jan 3 17:03:43.644 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.660 Router: Se1/1:27 LCP: I CONFREJ [REQsent] id 42 len 8
Jan 3 17:03:43.660 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.660 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 43 len 14
Jan 3 17:03:43.660 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.676 Router: Se1/1:27 LCP: I CONFREJ [REQsent] id 43 len 8
Jan 3 17:03:43.676 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.676 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 44 len 14
Jan 3 17:03:43.676 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.692 Router: Se1/1:27 LCP: I CONFREJ [REQsent] id 44 len 8
Jan 3 17:03:43.692 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.692 Router: Se1/1:27 LCP: O CONFREQ [REQsent] id 45 len 14
Jan 3 17:03:43.692 Router: Se1/1:27 LCP: MagicNumber 0x3E6D7AFD (0x05063E6D7AFD)
Jan 3 17:03:43.708 Router: Se1/1:27 LCP: I CONFREJ [REQsent] id 45 len 8
Jan 3 17:03:43.708 Router: Se1/1:27 LCP: AuthProto PAP (0x0304C023)
Jan 3 17:03:43.708 Router: Se1/1:27 LCP: Failed to negotiate with peer
Jan 3 17:03:43.708 Router: Se1/1:27 LCP: State is Closed
Jan 3 17:03:43.708 Router: Se1/1:27 PPP: Phase is DOWN [0 sess, 1 load]
Jan 3 17:03:43.708 Router: Se1/1:27 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
Jan 3 17:03:43.708 Router: Se1/1:27 LCP: State is Listen
Jan 3 17:03:43.708 Router: %ISDN-6-CONNECT: Interface Serial1/1:27 is now connected to 4232400480 xxxxxxx
Jan 3 17:03:44.236 Router: %LINK-3-UPDOWN: Interface Serial1/1:27, changed state to down
Jan 3 17:03:44.240 Router: Se1/1:27 LCP: State is Closed
Jan 3 17:03:44.240 Router: Se1/1:27 PPP: Phase is DOWN [0 sess, 1 load
prem
VIP Purple
Re: Error while connecting with PRI instead of bri
apparently there is a problem with your PAP authentication. Makes sure that the line:
ppp authentication pap
is configured on both your Serial0:15 (or whatever your D-channel is, might be Serial1/1:15 in your config), as well as any Dialer interfaces. Also check if you might have cut and pasted the password into your config, sometimes spaces at the end of a password get copied and pasted as well. Can you post the configuration of both routers ?
Georg
hi georg
hes not the only person getting connected to the pri there r already some peopl who all are getting connected with the same pap authentication.
i m manually typing the username and password in my router no changes done at the remote end.will get the config and post them tomorrow.
prem
95
