Error with Voice Health Monitor 1.1
Within Cisoworks I am trying to run the Voice Health Monitor Monitoring console. I receive the following error when running this.
Could not load console CustomizeAdminConsole.iccon
java.net.ConnectException.Connection refused: connect
This sounds like a service isnt running and the application cant connect to a port.
Any ideas?
Thanks...
Re: Error with Voice Health Monitor 1.1
I was able to get past the error with a re-install of the DFM application. The only other problem is I get this when trying to access the Real-Time dashboard within Voice Health monitor.
ava.io.FileNotFoundException: http://ckan0w01voip:1741/CSCOnm/classpath/share.jar
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.plugin.protocol.jdk12.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getHeaderField(Unknown Source)
at sun.plugin.protocol.jdk12.http.HttpURLConnection.checkCookieHeader(Unknown Source)
at sun.plugin.cachescheme.PluginURLConnection.downLoadFile(Unknown Source)
at sun.plugin.cachescheme.PluginJarCacheHandler.downloadJarFileToCache(Unknown Source)
at sun.plugin.cachescheme.PluginJarCacheHandler.cacheHandler(Unknown Source)
at sun.plugin.cachescheme.PluginJarCacheHandler.getJarFilesPath(Unknown Source)
at sun.plugin.AppletViewer.loadJarFiles(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Blue
What java plug-in version are you using since your VHM 1.1 is a pretty old version.
Bronze
We have seen customer scenarios that sometimes they miss share.jar, jcchart400J.jar, etc. a few jar files under "CSCOpx\www\classpath". Simply copy the missing jar files the error prompted from your CDONE to this directory.
Hi minie, I look the classpath folder and I can see the share.jar file. But I have the same problem. VHM 1.2, plug-in 1.3.1 downloaded from Cisco and Common Services 2.2.
Any idea? Thanks,
Hernan.
Bronze
Did the error say missing share.jar? Did you copy the file from CD to classpath directory? Did you clear browser cache and JAR cache?
Hello minie, the error is exactly missing share.jar file. I copied the file from CD to classpath folder and I clear the cache of the browser and the plug-in jar cache. But it doesn't work.
I closed the message window and then the Topology Services appears to me.
Any idea?
104
