Errors on NIM-LTEA-EA module installed on ISR 4331
Jonnyballgame34
I recently purchased two ISR 4331's and two NIM-LTEA-EA LTE modules for testing purposes.
I am getting the same errors on both after installing the modules:
*Sep 11 17:03:54.200: %SPA_OIR-6-OFFLINECARD: SPA (NIM-LTEA-EA) offline in subslot 0/1
*Sep 11 17:09:59.214: %SPA_OIR-3-EVENT_TIMEOUT: subslot 0/1: Timeout waiting for SPA OIR event
And I have an amber error light on the module.
I am not finding any special installation commands related to the modules.  Does anyone know where I can find more information on this?
I should add that the Sim in the module hasn't been activate yet, but I'm not sure why that woudl make a difference.
Show inventory is below as well, any advice is appreciated.  Thank you very much
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN: FLM2130V28V
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V02, SN: DCA212410SJ
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01, SN: JAB092709EL
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9 , VID: V04, SN: FDO21260PEV
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
2 Accepted Solutions
Gr8, thanks for the feedback
Please rate useful posts so can get the points allocated :)
Ahsan Rana
5 Replies 5
Jonnyballgame34
Should also add I'm getting this error
Slot 0 Bay 2 Board 0 Module[NIM-LTEA-EA] spa_type 0xD13 Daughter Board Not Present
mrana0101
this is because software is not able to identify the module.
Had the same behaviour - upgraded to isr4300-universalk9.16.03.04.SPA.bin
now the ISR4k is able to recognize the NIM-LTE-EA module.
hope you have figured this out already -:)
Ahsan Rana
Worked ...thanks
Ahsan Rana
Done ..thanks again for the help and sorry for the slow reply/rating.
