02-08-2006 02:41 AM - edited 03-03-2019 01:44 AM
I have a 1751 Router (Version 12.1(5)YB4) connected to a 2970 Switch (Version 12.2(25)SEB2), when I create a sub-inter face on the Router it accumulates errors (10% approx), the interfaces were configured with fixed speed and duplex settings and to trunk (dot1q), when I stripped back the sub-interface from the router and made the switch interface switchport access it works fine. This is not ideal as I do require the interfaces to be set to switchport mode trunk. Any ideas?
Thanks.
02-08-2006 02:58 AM
Just a few tips:
1: Did you use switchport nonegotiate on the 2970 trunk?
2: Were the vlans for which you had the subinterfaces defined also present on the 2970?
3: Are you able to upgrade the 1751 to a more recent release?
Hope this helps,
Leo
02-08-2006 03:30 AM
Hi Leo,
1) No I did not use switchport nonnegotiate, I stipulated switchport mode trunk.
2)Vlan was present on the 2970
3)Yes I can upgrade but Im not so sure that this is the problem.
The only WAN Service that was affected was Exchange all other applications that users access via this WAN interface was operating ok?
Norrie
02-08-2006 03:41 AM
Are you using the same vlan as native on both sides?
Is the native vlan set identically on both sides? (tagged or untagged)
Leo
02-08-2006 06:05 AM
The Vlan (at present) is only significant locally and is not asigned as native.
Norrie.
02-08-2006 06:26 AM
It seems as if you do not understand the point. There are two ways to transport packets between vlan capable devices. The most well known method is by using dot1Q encapsulation, the vlan-tag contains the vlan id. For compatability reasons the standard also involves the possible use of untagged traffic. This is done over the native vlan.
Problems can arise when one side is expecting untagged traffic but receives the traffic with a tag or vice versa. On switches, you can configure this by setting the native vlan
Both sides must be set identical, no data can be exchanged otherwise.
Leo
02-08-2006 07:06 AM
since you say that Exchange traffic is affected, there might be a problem with the MTU or MSS settings. Try and configure the following on your LAN (sub)interfaces and check if that makes a difference:
ip tcp adjust-mss 1350
Nethelper
