Webcast-Catalyst9k
Ether between distribution switch(GBIC)
Hi All!
can i do Ether chanel between 2 distribution switch(distance between the 2 Dist it 600M) via the 2 fiberPort(GBIC)what can i use in this Situation; single or MultiMode.ALSO CAN I KNOW THE WHICH SERIES of 2950 Can suppot the GBIC
10xs
Bronze
Re: Ether between distribution switch(GBIC)
As long as the connections are configured the same on both sides, etherchannel does not really care what transport medium you use. Are you refering to 10GigE for your connection?
hi
i'll use 1000baseSX.this is correct?also i need the specification for the 2950series that support GBIC Fiber
10xs
Ali
100
