Webcast-Catalyst9k
EtherChanel
i defined 4 gig port as an EtherChanel;do i need to configure something on the next side(Core) to negotiate or automaticaly the core see the channel(l2 link)
10xs
Re: EtherChanel
here you should have identical configuration on both the end...and when you cnofigure the ether channel then ports on both the switch will configure as the Layer3 port and then you are assigning them in to the etherchannel group...
and you are assinging the ip address to the interface port channel...
hope this helps you
rate this post if it helps
regards
Devang
Re: EtherChanel
hi
no ip address any more.i mentioned L2 Link.have a look to this config from the access side
interface GigabitEthernet0/25
switchport trunk encapsulation isl
switchport mode trunk
channel-group 5 mode on
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Port-channel5
switchport mode trunk.
where is my mistake in this config?and what is config from core side
10xs
Ali
Re: EtherChanel
Ali,
AFAIK I dont see any mistakes with this configuration of yours. What is the exact problem that you are facing???
The config on the core side would be the same as the above. Only the interface name would change accordingly.
Maybe the following URL might help:-
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00801cddad.html#1040179
Please rate the post if it helps.
AbhisheK
108
