Community Member
Etherchannel and misconfiguration
My 2 3750 are connected with 2 GiGe Link with etherchannel mode ON.
i wanted to add a VLAN on the trunk, so i did the "switchport trunk allowed vlan add" command on the 2 giga interface instead of the "logical port channel interface". so the 2 interfaces Giga have been immediatly "suspended" si the etherchannel was down
is it possible to devalidate this feature in order to avoid the type of probleme with a misconfiguration ?
Bronze
Re: Etherchannel and misconfiguration
try the global command:
no spanning-tree etherchannel guard misconfig
Nethelper
Community Member
I don't use STP, but i will try it anyway
thx
David
158
