Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Etherchannel between diferent chassis
Is possible to create an etherchannel between 2 GBIC interfaces of a Catalyst 4506 in one side and two GBIC interfaces of two different Catalyst 6000 chassis inthe other side?.
Gold
Re: Etherchannel between diferent chassis
should be no problem.
Thank you for your reply.
How can I do it? because I believed that the etherchannel only works between 2 switches, but not between one switch on one end amd 2 switches on the other end (in fact, this is the configuration I intend to deploy).
Bronze
I don't think you can do that. The Etherchannel must terminate on both ends into a single chassis AFAIK...
98
