EtherChannel Bundle for an HP Blade server
I'm running a Catalyst 6513 switch with Native IOS installed. I have created a EtherChannel bundle for an HP Blade server running with two clustered (teamed) NICs. The configurations are as follows:
interface Port-channel100
no ip address
switchport
switchport trunk allowed vlan 2
switchport mode trunk
end
interface GigabitEthernet10/35
description XPQASRV13 (Cable No.35)
no ip address
speed 100
duplex full
switchport
channel-protocol lacp
channel-group 100 mode active
end
interface GigabitEthernet11/42
description XPQASRV13 (Cable No.90)
no ip address
speed 100
duplex full
switchport
end
The problem is that running the interfaces at 1GiG causes the two NICs to insert and de-insert on the network every second but forcing them to 100 Meg makes them perform normally. These are connected using Cat5e cables which are 1GIG certified. What could be the cause for this problem?
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: EtherChannel Bundle for an HP Blade server
As per your mention, I think the problem is with the server on the other side. The speed is not compatible on the other. Why don't you set the speed/duplex to auto and check it out?.
156
