09-26-2006 05:59 PM - edited 03-03-2019 05:15 AM
Need to check if Giga Etherchannel can be configured between Copper 10/100/1000BaseT and SFP 1000BaseT between two blades on a Cat 6506 with either Sup 720 or Sup32.
09-26-2006 06:33 PM
I heard from one of my colleague that he has tested in a lab environment(Cat6509E-sup720) bundling the copper and fiber gig ports in the same etherchannel group.
But if you ask Cisco directly they say NO
09-26-2006 07:48 PM
According to cisco the speed and duplex settings on the links should be same for the etherchannel configurations.
So it shouldn't be a problem eventhough the links are from different media as far as the above equation holds true.
The best way would be to simulate this in a LAB and test
Narayan
09-26-2006 08:32 PM
Thanks.
09-27-2006 12:36 AM
I have configured etherchannel between two 3560G 48 port switches. Using a combination of 2 sx fiber and 2 1000tx copper interfaces. The resulting layer 2 channel supported upto 4gb. The notes from the cisco site indicate the following:
Configure all LAN ports in an EtherChannel to operate at the same speed and in the same duplex mode.
The following link refers to etherchannel for 6500 series switches:
This link refers to etherchannel for the 3560 series:
09-26-2006 08:32 PM
Thanks.
