Etherchannel delay?
hi all
i have an etherchannel setup between 3550 and a 3548. in testing when i disconnect one of the links it takes close to 10 seconds for the other link to start transmitting data from the test machine. i have data going over both links at all times. i also have load balancing set up for src-mac address. i was under the assumption that when one link fails the other picks it up within 1 second.
any help would be appreciated.
thanks
Steve
Bronze
Re: Etherchannel delay?
Steve,
Have you looked into the following example?
http://www.cisco.com/en/US/products/hw/switches/ps607/products_configuration_example09186a0080094789.shtml
Not really sure if that would help. Do you mind posting the config?
here are the interface configs:
3548
interface GigabitEthernet0/1
no ip address
channel-group 1 mode desirable
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 172.16.48.100 255.255.0.0
no ip route-cache
3550
spanning-tree mode pvst
interface Port-channel1
no ip address
no ip address
channel-group 1 mode auto
no ip address
in the article you referenced above, it show the interface as a trunk....i was thinking it only needed to be a trunk if you were using vlans...
thanks
steve
197
