07-21-2003 07:55 PM - edited 03-02-2019 09:00 AM
I have CD-one 5th edition, Campus Manager 3.2 and RME 3.2 and I have Giga-etherchannel connection in my network but this connection doesn't appear as Etherchannel in my Topology view, it is only single Gigabit connection. What is wrong with my LMS ?
thanks,
-rusdi-
07-22-2003 08:20 AM
Hi,Rusdi
You may just need to configure some IP addresses
on the ATM interfaces of the devices.
The goal of this change is that when you type
'show atm ilmi-status' the "Peer IP address"
parameter won't be 0.0.0.0 since Campus needs
this data to draw the link.
The following link provides useful information about ANI discovery and specifically addresses ATMlinks:
* Make sure CDP is enabled on both sides of the ports.
Something else to try would be updateing your IDU patches.
Here are the links :
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus
Best Regards,
Joseph melrose
07-22-2003 04:05 PM
Joseph,
my network is not ATM network but many thanks for your respond.
I will try to update IDU patch.
btw, my network is Cat6509 which is connected to other cat6509 by using gigabit etherchannel.
thanks,
-rusdi-
