Webcast-Catalyst9k
Etherchannel issue on tunnel
i have a VPN tunnel between two of our offices. The links are provided by two service providers .Both links are 45 Mbps ethernet hands off. I have created ether channel between the two links.The connection is like
PIX ---- L3 switch1---Service providers----switch2----- PIX2. Port channel is working fine as a 90 Mbps link. But i can see in my MRTG that always one link is in use . other link trafic is in mere Kbps. Switch port channel config is as follows:
Switch 1:
vlan 10
name MAN_CONNECTION
interface Port-channel10
switchport trunk native vlan 10
switchport mode trunk
interface FastEthernet1/0/2
description "TTSL"
load-interval 30
duplex full
speed 100
channel-group 10 mode desirable non-silent
interface FastEthernet1/0/3
description "Airtel"
load-interval 30
duplex full
speed 100
Switch 2:
vlan 10
name MAN_CONNECTION
logging event bundle-status
description "TTSL"
load-interval 30
duplex full
speed 100
load-interval 30
duplex full
speed 100
Can some body give a clue ,why only one link is loaded. both the links are 45 MBps.
Thank you
Ullas Upendran
Silver
Re: Etherchannel issue on tunnel
Load sharing is based on L2 information.
source address is PIX1
destination address is PIX2
XOR load-balances on this information. Because the source/destination address is the same for all frames no real load-balancing is performed.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
--Leon
Thanks leon. But the switch i have on both sides are Layer 3 and is doing routing also .
the full switch config is as follows.
hostname MAN-Ulsoor-3750
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
ip routing
vtp domain PIC
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 10
name MAN_CONNECTION
interface FastEthernet1/0/1
shutdown
description "TTSL"
load-interval 30
duplex full
speed 100
load-interval 30
duplex full
speed 100
interface FastEthernet1/0/23
description *** PIX-Ulsoor Standby ***
duplex full
speed 100
interface FastEthernet1/0/24
description *** PIX-Ulsoor Active ***
duplex full
speed 100
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface Vlan1
ip address 10.253.253.27 255.255.255.248
interface Vlan10
ip address 10.253.253.18 255.255.255.248
ip default-gateway 10.253.253.25
ip classless
ip route 0.0.0.0 0.0.0.0 10.253.253.25
ip route 10.253.253.0 255.255.255.248 10.253.253.17
ip route 10.253.253.8 255.255.255.248 10.253.253.17
ip route 161.85.28.0 255.255.254.0 10.253.253.17
ip route 161.85.97.0 255.255.255.0 10.253.253.17
ip route 161.85.99.0 255.255.255.0 10.253.253.17
ip route 161.85.102.0 255.255.255.0 10.253.253.17
ip route 161.85.103.0 255.255.255.0 10.253.253.17
no ip http server
ip tacacs source-interface Vlan1
Even if the sourse ip is of the switch ,load balancing is not possible? As my second link is always idle ,is there any way i can utilise it?
Ullas
ullas,
i think actully load balancing work lik this...
Load distribution is based on the source-MAC address of the incoming packet. Packets from different hosts use different ports in the channel, but packets from the same host use the same port in the channel.
When src-mac is used, load distribution based on the source and destination IP address is also enabled. For all IP traffic being routed, the switch chooses a port for transmission based on the source and destination IP address. Packets between two IP hosts always use the same port for packet transmission, but packets between any other pair of hosts might use a different transmission port.
Load distribution is based on the destination-host MAC address of the incoming packet. Packets to the same destination are sent on the same port, but packets to different destinations are sent on different ports in the channel.
may this will help you in configuration...
rate this post if it helps
regards
Devang
This command is suppose to allow for source and destination IP loadbalancing on a etherchannel.
Router(config)#port-channel load-balance src-dst-ip
Use
Router# show etherchannel load-balance
to view what type loadbalancing is in use.
Richard
hi richard
the out put shows
MAN-Ulsoor-3750#sh etherchannel load-balance
Source MAC address
MAN-Ulsoor-3750#
thanks ullas
Silver
Please refer to the documentation of your 3750 switch. See the Etherchannel documentation on Load Balancing:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swethchl.htm#wp1275731
The problem is that you have a static source/destination which makes load-balancing accross an etherchannel difficult.
--Leon
Hi all
i configured etherchannel load balancing with source ip on both the switches . Now i can see the traffic is evenly going in both the links.Thanks a lot
Ullas
213
