Etherchannel issue
HI all,
Here is the relevant output in the config, I´m trying to create an etherchannel between a 3750 switch (working in stack mode) and 7304 router.
ROUTER 7304
interface Port-channel10
no ip address
no negotiation auto
no clns route-cache
hold-queue 150 in
interface Port-channel10.1100
encapsulation dot1Q 1100
ip address 192.168.100.1 255.255.255.0
interface Port-channel10.1200
encapsulation dot1Q 1200
ip address 192.168.200.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
no negotiation auto
channel-group 10
no clns route-cache
interface GigabitEthernet2/1
no ip address
no negotiation auto
channel-group 10
no clns route-cache
Switch 3750 (stack)
vlan 1100,1200
switchport trunk allowed vlan 1100-2000
switchport mode trunk
interface GigabitEthernet1/0/25
channel-group 10 mode on
interface GigabitEthernet2/0/25
interface Vlan1100
ip address 192.168.100.2 255.255.255.0
interface Vlan1200
ip address 192.168.200.2 255.255.255.0
The thing is that config looks fine, interfaces (and vlans) are UP, all appears to be working OK in layer 2, but there is no connectivity in layer 3, ping don´t work.
Any idea?
thanks in advance
  • Other Network Infrastructure Subjects
Re: Etherchannel issue
Few quick checks on the physical status of all the virtual as well as physical interfaces.
Also the status of the SVI interfaces and normal vlan status in 3750.
are you trying to ping the router from the switch or trying to ping from router to switch ?
Any routes or any routing protocol being configured in the switch as well as in the router ??
regds
Purple
What are you trying to ping . In order to have the layer 3 interface up on the 3750 you will need at least one active user on that switch in that vlan otherwise the SVI will be up/down I believe . Check that the trunk and etherchannel are working ok, do a show interface trunk and a show etherchannel detail and make sure the trunk and etherchannel are correct.
I´m trying to ping the switch from the router and also the router from the switch, routing is OK and all the interfaces are UP, there´s traffic in the interfaces counters.
I´m going to try any debug...
Bronze
Try the following ping
ping ip 192.168.100.2 source 192.168.100.1
ping ip 192.168.100.1 source 192.168.100.2
Yes, I was trying that but no way, another more thing is when I put the interface of the 7304 out of the etherchannel I can see the switch with the sh cdp neig but when interfaces are grouped to teh etherchannel there is no way no see the switch via cdp. I can see always the router from the 3750 via cdp.......
any idea?
129
