Community Member
etherchannel problem
I connect two 6509 with two 100M fastethernet using etherchannel.But the port of one 6509 will report
errdisable.It can work normal if I reenable it. But after a while,console will report:
%SPANTREE-2-CHNMISCFG: STP loop - channel 3/1-2 is disabled in vlan 11.
and the port will become errdiable.
So I verify the configuration of the port 3/1-2:
1.all port belong to vlan1
2.etherchannel mode is set to on
3.the UTP 5 is correct.
I don't know why,pls help me,thanks!
Community Member
Re: etherchannel problem
Have you verified your channeling is working correctly??
show port channel?
Sounds like its not, if STP is seeing a loop, the link is still 2 logical links, not 1 logical link (2 phyiscal) Ensure your duplexing and so on is all set the same
Just my thoughts.
Community Member
if I reenable the errdisable port and show port channel,result is following:(I think duplexing and so on is all set the same)
6506A> (enable) sh port channel
Port Status Channel Admin Ch
Mode Group Id
3/1 connected on 10 833
3/2 connected on 10 833
Port Device-ID Port-ID Platform
3/1 SCA05020CZS 3/1 WS-C6506
3/2 SCA05020CZS 3/2 WS-C6506
6506A> (enable)
noc
Community Member
make sure portfast is disabled on those ports
set spantree portfast 3/1-2 disable
and do a
set port duplex full 3/1-2
set port speed 100 3/1-2
check your switches vlan bridge priority in vlan 11
show spantree 11
make sure your "ROOT" is determined by your design, not by other things like lower mac addresses etc.
you should have BOTH sides set exactly the same for duplex and speed ..
141
