Etherchannel Problems 6509 - 3560G
I have configured 2 ports on my Catalyst 6509 to be members of an etherchannel like so:
set port channel 3/3, 3/17 mode desirable non-silent
On the 3560 I have done the following
interface gi0/1
channel group 1 mode desirable
interface gi0/24
(both these are dot1q trunks) native VLAN150
One of the interfaces on the 3560G can join the Port-Channel. I am getting the following message
Gi0/1 suspended: incompatable partner port with GigabitEthernet0/24
The strange thing is i done a shut on the port channel, then no shut, Gi0/1 joined the PortChannel and the message was the oppisite of that above.
Any help would be greatly recieved.
Gav
Hall of Fame Super Bronze
Re: Etherchannel Problems 6509 - 3560G
With CATOS (6509) you have two steps.
First step, you need to bundle the ports.
Second step (which you've done), you need to set the mode
You can verify the config on the CATOS with the 'show port channel' command.
_____
Please rate helpful posts.
Ok
I done the 2 steps in one... made the ports part of etherchannel 1 and set the mode?
why do I get incompatable port types?
Gav
With CATOS you can't do the 2 steps in one.
You have to type the 2 commands I posted in order for this work.
by the way the command show port channel does not show that any channel has been config
Gav
Because you haven't bundled the ports.
Please type the commands as I posted.
Silver
Will the problem repeated on other ports ? Or on these specific port only ?
If you disconnect the cables then connect one by one, what is the result ?
Silver
Moreover, I think you are configure as Layer 2 Etherchannel. Please check below link for the CatOs & IOS Etherchannel info.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094953.shtml
Finally, can you check the "show port capabilities" in 6509 ? And, did you try to use "auto" or "on" in etherchannel mode ? And try "silent" mode too. Check below for different mode result :
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a00800949c2.shtml#manualconfig
Hope this helps.
413
