EtherChannel (Unknown duplex, Unknown Speed, unknown 0)
Hi..
I want to connect Cat4506 (Version 12.1(13)EW) and Cat 6509 (Version 12.1(8b)E13) over two gigabit fiber ethernet links. I configured etherchannel like this:
4506#sh run
interface Port-channel1
switchport
switchport trunk encapsulation isl
switchport mode trunk
interface GigabitEthernet1/1
channel-group 1 mode on
interface GigabitEthernet1/2
6509#sh run
no ip address
switchport
interface GigabitEthernet3/1
no ip address
switchport
interface GigabitEthernet3/2
no ip address
switchport
On 4506 when i issue this command :
4506#show interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 000c.850e.a780 (bia 000c.850e.a780)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
output flow-control is unsupported, input flow-control is unsupported
Members in this channel: Gi1/1 Gi1/2
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 00:17:59
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 38000 bits/sec, 17 packets/sec
4190 packets input, 436595 bytes, 0 no buffer
Received 4067 broadcasts (0 multicast)
20529 packets output, 5859682 bytes, 0 underruns
0 lost carrier, 0 no carrier
What is the reason of "Unknown duplex, Unknown Speed, unknown 0"
Note:When i issue the same command on 6509 there is no problem:
6509#sh interfaces port-channel 1
Hardware is EtherChannel, address is 0009.11f3.88e8 (bia 0009.11f3.88e8)
Full-duplex, 1000Mb/s
Members in this channel: Gi3/1 Gi3/2
Output queue :0/40 (size/max)
28226 packets input, 7157872 bytes, 0 no buffer
Received 27461 broadcasts, 0 runts, 0 giants, 0 throttles
6767 packets output, 717312 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Bronze
Re: EtherChannel (Unknown duplex, Unknown Speed, unknown 0)
It might be a bug with Cisco IOS 12.1(13)EW. Try to upgrade to 12.2(14)SY2 and see the output. And also because of port channel is the virtual interface, I think that output is not so important and hope your setup is working fine now.
Did it channel? I would also like to know what the physical interfaces were configured like. Are they in the automatic duplexing and speed mode? This appears to be recommended even though the gig ports are 1000 full, there are additional benefits of auto negotiating and the negotiation is really a sham since the ports are 1000 full no-ifs-no-buts; in reality negotiation takes no time. See link below:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml#auto_neg_valid
472
