Community Member
Etherchannel with 2950 and 2948
I have a 2950 with 4 ports grouped as 1 and connect them to a 2948. When I pull the 2nd, 3rd and 4th cable. ping was still ok. When I put back the 2nd cable ping timeout occurs. When I put back the 3rd cable it went fine again. Is this a feature or a bug? Maybe anyone can shed light on this. Thnks.
Re: Etherchannel with 2950 and 2948
Use channel mode desirable on both switches
http://www.cisco.com/warp/public/473/140.html
Also make sure the CAT2948G is running latest 6.3(x) since it has etherchannel enhancement
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_2117.htm#xtocid11
Community Member
Will this work with 2950 with IOS 12.0(5.3)wc(1) and 2948G-L3 with IOS V.12.0(7)WS(1SD)? Im not sure about the difference between CatOS and Native OS.
200
