Ethernet Interface for ISL Routing in 2610 ???
Hi anyone please clarify if I were to use the subinterface of ethernet ports(e0/0.1,e0/0.2...) in 2610 to conduct the ISL routing for few VLANs instead of using the fastethernet port, is it alright to that ?
Maximum how many subinterfaces can be created over one physical ethernet port of 2610 ?
Is there any difference by using e0/0 and fast0/0 ?
Please help out.
Re: Ethernet Interface for ISL Routing in 2610 ???
You cannot create sub interfaces on a 10 mbps port. 2610 has a 10mbps port. Sub interfaces can be created only on 100 mbps ports. You should be looking forward for a 2620 atleast to do this.
You can find the maximum number of subinterfaces allowed per platform, it is an IOS version dependant.The maximum number of interfaces a router can handle depends on the maximum number of IDBs it can use.
http://www.cisco.com/warp/public/63/idb_limit.html
203
