ethernet problem
I saw a strange situation at one of our customers. Platform is Cisco 1760 running 12.2.2.XK2, attached to a hub(100Mbps). There are two clients on the ethernet. This 1760 is attached to the head office with 64Kbps Leased line. The client can ping the head office and can start AS/400 session, but can not be pinged by any other clients(in head office), servers and even by its gateway(c1760). The client can be seen in the output of "show arp" in the gateway Cisco 1760 but can not be pinged at all. But this client can ping its gateway. At the same time i can see some traffic on serial port ( by sh int serial x/y) but can see only the following rows in the "show interface Fastethernet0/0" command:
but input packet and output packet numbers are increasing.
Do you have any idea, ewhat is happening to this router?
sincerely,
yoguz.
1 ACCEPTED SOLUTION
Silver
Re: ethernet problem
have the windows 2000 box do a route print examine the route print fir discrepencies
also can the clinet be pinged for other hosts on the same segment ?
Pls check the reverse route in head office for remote office subnet and also the IP subnet addressing for ethernet and client pcs in remote office.
I checked all the ip/subnet configuration. There is no problem with them.
can u put the config.
here is the configuration and some output of some commands. and alla people can do voip calls with this ethernet ip addresses. now i'm going to check the hub. do you have any other ideas?
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ANKARA
logging buffered 8192 debugging
enable password 7 xxxxxxxxxxxxxxxx
ip subnet-zero
interface Multilink1
description merkez
ip unnumbered Fastethernet0/0
fair-queue 128 128 0
no cdp enable
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
multilink-group 1
ip rtp priority 16384 16383 24
interface FastEthernet0/0
ip address 10.31.253.254 255.255.255.0
speed auto
interface Serial0/0
description merkez baglantisi
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
router eigrp 100
network 10.0.0.0
network 192.168.10.0
network 192.168.20.0
network 192.168.30.0
network 192.168.40.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip http server
call rsvp-sync
voice-port 1/0
cptone TR
type 5
voice-port 1/1
cptone TR
type 5
mgcp profile default
dial-peer cor custom
dial-peer voice 101 pots
answer-address 52..
destination-pattern 52..
port 1/0
prefix 52
dial-peer voice 102 pots
answer-address 52..
port 1/1
prefix 52
dial-peer voice 103 voip
destination-pattern 1...
session target ipv4:192.168.10.1
ip qos dscp cs5 media
dial-peer voice 106 voip
destination-pattern 53..
session target ipv4:10.47.249.254
dial-peer voice 107 voip
destination-pattern 54..
session target ipv4:10.15.253.254
dial-peer voice 108 voip
destination-pattern 51..
session target ipv4:10.31.254.254
dial-peer voice 109 voip
destination-pattern 55..
session target ipv4:10.14.254.254
dial-peer voice 110 voip
destination-pattern 56..
session target ipv4:10.15.254.254
dial-peer voice 111 voip
destination-pattern 57..
session target ipv4:10.47.248.254
dial-peer voice 112 voip
destination-pattern 58..
session target ipv4:10.31.252.254
dial-peer voice 113 voip
destination-pattern 3...
session target ipv4:192.168.30.1
dial-peer voice 114 voip
destination-pattern 4...
session target ipv4:192.168.40.1
dial-peer voice 104 voip
destination-pattern 2...
session target ipv4:192.168.20.1
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
ANKARA#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.31.253.254 - 0007.8580.6466 ARPA FastEthernet0/0
Internet 10.31.253.1 3 0080.ad89.5f06 ARPA FastEthernet0/0
ANKARA#
ANKARA#ping 10.31.253.1
Sending 5, 100-byte ICMP Echos to 10.31.253.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ANKARA#sh ip route 10.31.253.1
Routing entry for 10.31.253.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 100
Routing Descriptor Blocks:
* directly connected, via FastEthernet0/0
Route metric is 0, traffic share count is 1
Silver
is the client 10.31.253.1 using 2 nic's or have 2 nic's installed ? If a windows box have them do a route print and examine the routing tabe of the box
No it's an ordinary client with 1 nic, running Windows2000.
Silver
Outside of any possible routing issue, does the 2000 box happen to run any software firewalls that would prevent ICMP? This could cause a ping to respond that was sourced from this host, but not allow another host outside to get a ping response.
Thanks so much for your brian storming. The problem is solved. No routing or router problem. It was just because of NIC card and it's driver of 2000 box.
103
