Ethernet/ Token ring conversion
currently have a 16MB token ring network, which I am in the process of converting to fast/ GB ethernet. I have a point to point T1, which is fractionalized by a Paradyne 3160 CSU, which connects to an IBM 2210 token ring router. I am looking for suggestions as to what to replace it with. I need the capability to plug in two fractionalized T1s and connect the router to my ethernet network. I was looking at the 2600 series with a 2 port FT1 WIC. Am I on the right track
1 REPLY
VIP Purple
Re: Ethernet/ Token ring conversion
the 2600 would definitely work. Here is a list of devices that meet your requirements, including the list prices, just to give you an indication of the cost:
Cisco 1721 CISCO1721 10/100BaseT Modular Router w/2 WAN slots, 16M Flash/32M DRAM $1,195.00
Cisco 1751 CISCO1751 10/100 Modular Router w/ 3 slots, IOS IP, 16F/32D $1,495.00
Cisco 1760 CISCO1760 10/100 Modular Router w/ 2WIC/VIC,2VIC slots,19 inch Chassis $1,595.00
Cisco 2610XM CISCO2610XM 10/100 Ethernet Router w/ Cisco IOS IP $1,995.00
Cisco 2610XM-DC CISCO2610XM-DC 10/100 Ethernet Router w/ Cisco IOS IP - DC Power $2,495.00
Cisco 2611XM CISCO2611XM Dual 10/100 Ethernet Router w/ Cisco IOS IP $2,495.00
Cisco 2611XM-DC CISCO2611XM-DC Dual 10/100 Ethernet Router w/ Cisco IOS IP - DC $2,995.00
Cisco 2620XM CISCO2620XM Mid Performance 10/100 Ethernet Router with Cisco IOS IP $2,295.00
Cisco 2620XM-DC CISCO2620XM-DC Mid Performance 10/100 Ethernet Router w/Cisco IOS IP-DC $2,795.00
Cisco 2621XM CISCO2621XM Mid Performance Dual 10/100 Ethernet Router w/Cisco IOS IP $3,095.00
Cisco 2621XM-DC CISCO2621XM-DC Mid Performance Dual 10/100 Ethernet Rout w/Cisco IOS IP-DC $3,595.00
Cisco 2650XM CISCO2650XM High Performance 10/100 Modular Router w/Cisco IOS IP $3,295.00
Cisco 2650XM-DC CISCO2650XM-DC High Performance 10/100 Modular Rout w/Cisco IOS IP-DC NEBs $3,795.00
Cisco 2651XM CISCO2651XM High Performance Dual 10/100 Modular Rout with Cisco IOS IP $4,195.00
Cisco 2651XM-DC CISCO2651XM-DC High Performance Dual 10/100 Modular Rout w/IP-DC NEB $4,695.00
Cisco 2691 CISCO2691 High Performance 10/100 Dual Eth Router w/3 WIC Slots,1 NM $6,295.00
Cisco 3620 CISCO3620 Cisco 3600 2-slot Modular Router-AC with IP Software $2,900.00
Cisco 3620-DC CISCO3620-DC Cisco 3600 2-Slot Modular Router-DC with IP Software $3,400.00
Cisco 3661 AC CISCO3661-AC 10/100 E Cisco 3660 6-slot Modular Router-AC with IP SW $10,700.00
Cisco 3661 DC CISCO3661-DC 10/100 E Cisco 3660 6-slot Modular Router-DC with IP SW $11,200.00
Cisco 3662 CISCO3662-AC Dual 10/100 E Cisco 3660 6-slot Modular Router-AC with IP SW $11,700.00
Cisco 3662-DC CISCO3662-DC Dual 10/100 E Cisco 3660 6-slot Modular Router-DC with IP SW $12,200.00
Cisco 3725 CISCO3725 Cisco 3700 Series 2-slot Application Service Router $8,500.00
Cisco 3745 CISCO3745 Cisco 3700 Series 4- Slot Application Service Router $12,000.00
Cisco 7204VXR-CH CISCO7204VXR-CH Cisco 7204VXR, 4-slot chassis, 1 AC Supply w/ IP Software $6,000.00
Cisco 7206VXR-CH CISCO7206VXR-CH Cisco 7206VXR, 6-slot chassis, 1 AC Supply w/ IP Software $7,000.00
Cisco 7401ASR-CP CISCO7401ASR-CP 7401ASR,128M SDRAM, IP Software $12,000.00
Georg
96
