Community Member
etherswitch and routing
Is it possible for and etherswitch module on a 3745 or 3725 to the fastethernet ports as routers ports ?
Or use vlan from the etherswitch module to make the 37.. between them ?
Best regards
1 ACCEPTED SOLUTION
Re: etherswitch and routing
No you cannot use them as routed ports
3745-A(config-if)#ip address 10.1.1.1 255.255.255.0
% IP addresses may not be configured on L2 links.
The following page should help as well
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xt/122xt_2/ft1636nm.htm
1 REPLY
109
