Webcast-Catalyst9k
Exporting Data from 6K NAM - Help required
I want to know, is there anyway to export the data from Cat 6K NAM. If so, to which database server do I export and how do I access the same?
The module runs the NAM firmware 2.1(2)
Please advise.
Raj
Re: Exporting Data from 6K NAM - Help required
Raj
Using the web interface for the NAM you
http://
Login
1) Capture the data
Capture->Setttings Start the capture
Capture->Setttings Pause the capture
2) Download
Download->Save Buffer to file
Download ->Download file
This will save the capture to your local machine and can be viewed withe Ethereal or Sniffer Pro.
phil
Phil:
Thanks for your advise. But is there any way of automating it? I mean, any possibility to write it in a script? If, so please guide me.
Raj
Blue
No, there's is no automated way to do this. The reason being that NAM Traffic Analyzer does not have any database to save any historical trending. You can only do a Data Capture in real time and then download it for further use.
128
