Webcast-Catalyst9k
Facing problem with compression
We have more branches which are connected through 128 k leased line to my headoffice router.
when I put compression stac on ser0 int branch1 router and ser1 headoffice router its working fine but after two days my branch servers cannot see my headoffice servers and that time when I remove the compression stac it can see each other and again after two days the same problem and when I put again compression it sees each other. How to rectify this ?
1 REPLY
Anonymous
N/A
Re: Facing problem with compression
You may want to ensure that both routers
are running recent code to avoid any potential
STAC bugs; you may also want to try comparing
the results of predictor compression versus
STAC.
92
