Webcast-Catalyst9k
fastethernet ports: errordisable problem
Fastethernet ports 2950 fall into errordisable state however UDLD aggressive is enabled globally for the fibre port only. No per interface UDLD configuration is present.
Why would fa ports go Errdisabled if not running UDLD on a port by port basis.?
Is this a code bug?
1 REPLY
Re: fastethernet ports: errordisable problem
There are many more reasons for a switchport to go into errdisable. This is on a 3550:
SWITCH>sho errdisable det
ErrDisable Reason Detection status
udld Enabled
bpduguard Enabled
security-violatio Enabled
channel-misconfig Enabled
psecure-violation Enabled
dhcp-rate-limit Enabled
unicast-flood Enabled
vmps Enabled
pagp-flap Enabled
dtp-flap Enabled
link-flap Enabled
l2ptguard Enabled
gbic-invalid Enabled
loopback Enabled
Link-flapping is the most common one AFAIK.
Have you checked the log? Normally the log gives the reason.
98
