FEC between DL580 servers and cat2924/cat5509 switches
We have four servers ( compaq dl580 ) with two Gigabit NIC each.
Two of them are connected to a 2924 and the other two to a cat 5509.
We'd like to configure each server with FEC .
For the 2924 I did the following configuration
interface Port-channel2
switchport mode trunk
flowcontrol send off
interface FastEthernet0/4
description gdbo01CLN2-1
no cdp enable
channel-group 2 mode on
interface FastEthernet0/6
description gdbo01CLN2-2
no cdp enable
Is this correct ? Do I need to add anything ?
Which configuration is needed to do the same on the cat 5509 ?
thanks
Re: FEC between DL580 servers and cat2924/cat5509 switches
This is correct, except that you should not set these ports to trunk. Make them acess ports instead.
with us, it works like this for about a year now:
description
no ip address
switchport
switchport access vlan 14
interface FastEthernet5/47
description Channel2
no ip address
logging event link-status
switchport
no cdp enable
spanning-tree portfast
interface FastEthernet5/48
no ip address
switchport
no cdp enable
With a C5509 (CatOS) I would like to help you but unfortunately I cannot spare the the time to check this out.
Leo
Hi Leo ,
thanks for your input .
Just a question , as I'm not so familiar with VLAN yet . We have just the default VLAN1 in our domain so can I just put "Switchport access Vlan 1" in the ethernet interfaces config?
Can you spare a few info regarding the trunk?
I thought trunking was the only method to have the bandwith doubled, with you configuration do I have only fault tolerance or bandwith aggregation too ?
thanks again
144
