Fiber connection between Cisco 3508 and Cisco 3750
I have a trunk configured between a cisco 3508 and a cisco 3750. I checked the fiber and it is OK. The configurations are below. I have taffic in one direction only. Am I missing a comand or is there a problem to have a trunk between the two devices?
Cisco 3750
interface GigabitEthernet1/0/26
no ip address
interface GigabitEthernet1/0/27
switchport mode trunk
no ip address
udld port aggressive
interface GigabitEthernet1/0/28
no ip address
Cisco 3508
interface GigabitEthernet0/5
interface GigabitEthernet0/6
description Connection to SW3750 for SAN -Blg 101
udld enable
interface GigabitEthernet0/7
1 REPLY
Re: Fiber connection between Cisco 3508 and Cisco 3750
Lets start with the obvious are you sure the GBIC's are working correctly, if you are then remove UDLD, it could be a bug but i did a quick scan and came up empty BUG'd, also not sure what IOS version you are running.
Dale
328
