Fiber connection SX from 3550G
I have 3550-12G with all the 1000-baseSX module inserted and acting as core switch with all the WS-C2950G-24EI connecting back.Can I insert the 1000-baseSX module into WS-C2950G-24EI to make a backbone connection to the 1000base-SX on the 3550-12G.
1 REPLY
Re: Fiber connection SX from 3550G
Yes, you can connect the 3550 and 2950 above with sx gbics. The 1000base-sx gbic is supported on the 2950G-24ei.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12111yj4/lrehig/hgovrev.htm
106
