Community Member
Fiber Range
i want to connect 12 Sites with any switch using fiber port.
my maximum distance is about 1.7 KM and mimum is 700M
so how i solve this what tool/products should i use. remember i want to use in Multimode
waiting for the best proposal from your side.
Re: Fiber Range
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources online at http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Community Member
Re: Fiber Range
Hi Wajahat
If your demand is strict to stic on Multimode then you have to use 10Base FL technology. Which supports up to 2KM. you can find many products through cisco web site.
regards,
Dilip/Jevin
93
