06-02-2004 01:48 PM - edited 03-02-2019 04:06 PM
Are there any commands that I could issue to the switch that would give me back the port info if I know either the IP address of a workstation or it's MAC address? Meaning I want to know where a particular workstation is plugged in without tracing cables.
06-02-2004 04:01 PM
sh arp
This will give you the stations IP adress, MAC address and the VLAN it belongs to. Once you have this info you can use the
sh mac-address-table vlan #
This will show you the MAC address and which port it's connected to.
sh mac-address-table ?
This will give you all kinds of options you can use to drill down to whatever your needs may be.
Hope this helps.
06-04-2004 06:09 AM
sh mac-add add 00d0.d456.0000
This will give you the exact port number of where that mac address it on the switch. I use this one all the time.
I would suggest putting a description on the port when you find it. Very helpful in the future.
thanks
tony
