06-11-2002 10:37 PM - edited 03-01-2019 10:08 PM
Currently I have a BRI port on my 3620 router as a backup link to primary link. Anyone know that how do I configure the router that in order to fire up the 2nd b-Channel of ISDN even though from the NT1, out of two S/T ports, physically I use only one of it to connect to my 3620 router.
Please guide.
06-12-2002 10:32 AM
This will depend on the NT config, but you should be able to connect with 2 B-channels and one NT (one port off the NT). You should try configuring the SPIDs (not sure what switch-type you have, or if you have SPIDs), a load-threshold, and
ppp multilink. Check that "sh isdn stat" says MULT_LAYER_ESTAB for both B channels, and that both have TEI's assigned. Debug isdn event and debug isdn q921 may help you as you try different configuration iterations.
06-12-2002 06:50 PM
Hi johnson, may I know what do the SPIDs and "load-threshold" commands here help to fire up the 2nd B channel ?
You said it 's dependent on the NT box config, so how do I configure the NT in oder to meet my requirement ? (As I know there is no configuration mode/button on the NT box).
Please guide.
