Flash memory card
Hello!
Could anyone please explain why when I am trying to copy files or erase filesystem to or from flash memory card the IOS doesn't allow do that:
Router#copy flash:1: slot0:
%Destination file system is read-only.
Router#erase slot0:
Erasing the slot0 filesystem will remove all files! Continue? [confirm]
%dev_open: PCMCIA Slot0 flash not writable
%Error erasing slot0: (Device is read-only)
The flash memory card I have is from Cisco Intel value series 200 24Mb memory card. And I was trying do that on 3640 router:
Router#sh ver
IOS (tm) 3600 Software (C3640-I-M), Version 12.2(5a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 04-Oct-01 13:46 by pwade
Image text-base: 0x600089A8, data-base: 0x60A54000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 7 minutes
System returned to ROM by reload
System image file is "flash:c3640-i-mz.122-5a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID 26392720
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash partition 1 (Read/Write)
16384K bytes of processor board System flash partition 2 (Read/Write)
Configuration register is 0x2101
Thank you in advance,
Router#sh ver
Bridging software.
Victor.
1 REPLY
Silver
Re: Flash memory card
From your show version output, the router is ont seeing your PCMCIA flash, confirm if if you are using the right type for the router.
132
