flash memory issue - cisco 1710 - how do i erase flash memory?
hello,
i tried to upgrade a 1710 box and i got the "SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!" message.
no wi'm trying to go back to the old version which was loaded on the box but i keep getting the same message.
here you have some output info from the box - maybe you can come with a new idea - i tried tftpdnld, xmodem ... and so on...
thx.
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > dir flash:
File size Checksum File name
6484004 bytes (0x62f024) 0x3014 c1710-k9o3sy-mz.122-4.YA2.bin
rommon 2 >
rommon 2 >
rommon 2 >
rommon 2 >
rommon 2 > confreg
Configuration Summary
(Virtual Configuration Register: 0x2142)
enabled are:
load rom after netboot fails
ignore system config info
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C1700
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]: y
enable "use net in IP bcast address"? y/n [n]: n
disable "load rom after netboot fails"? y/n [n]: y
enable "use all zero broadcast"? y/n [n]: y
enable "break/abort has effect"? y/n [n]: y
disable "ignore system config info"? y/n [n]: y
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]:
(Virtual Configuration Register: 0x9c22)
enabled are:
diagnostic mode
console baud: 115200
disable "diagnostic mode"? y/n [n]: C1700 platform with 32768 Kbytes of main m
emory
program load complete, entry point: 0x80008000, size: 0x62ef08
Self decompressing the image : #################################################
########################################################################## [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C1700 Software (C1710-K9O3SY-M), Version 12.2(4)YA2, EARLY DEPLOYMENT R
ELEASE SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 22:18 by ealyon
Image text-base: 0x80008124, data-base: 0x80BED550
System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
*** Reserved LVL 7 Interrupt ***
PC = 0xfff0bc98, Vector = 0x500, SP = 0x80004ce4
bytes of main memory
monitor: command "boot" aborted due to user interrupt
rommon 1 >
PC = 0xfff0bcb4, Vector = 0x500, SP = 0x80004de4
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > confreg
enabled are:
console baud: 9600
enable "use net in IP bcast address"? y/n [n]: y
enter to boot:
0 = ROM Monitor
2-15 = boot system
[2]: 0
(Virtual Configuration Register: 0xdc20)
enabled are:
diagnostic mode
boot: the ROM Monitor
do you wish to change the configuration? y/n [n]: n
You must reset or power cycle for new config to take effect
rommon 2 > reset
ÿ슈ÄüŽ÷Åü
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > xmodem
usage: xmodem [-cyrx] <destination filename>
-c CRC-16
-y ymodem-batch protocol
-r copy image to dram for launch
-x do not launch on download completion
rommon 2 > BB0BB0xmodem
monitor: command "BB0BB0xmodem" not found
rommon 3 >
rommon 3 >
rommon 3 >
rommon 3 >
rommon 3 > xmodem c1710-k9o3sy-mz.122-4.YA2.bin
Do not start the sending program yet...
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c1710-k9o3sy-mz.122-4.YA2.bin ...
Erasing flash at 0x60fe0000
Programming location 60620000
Download Complete!
Stack pointer : 0x02000000
monstack : 0x800063EC
monra : 0x00000000
edata : 0x8000C0D0
magic : 0xFEEDFACE
memsize : 0x02000000
uncomp_size : 0x010C1440
comp_size : 0x0062AE22
comp_checksum : 0xDAFC8EC9
uncomp_checksum : 0x78D1F2EE
Source elf_hdr->e_shnum = 0x0000000A
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000001B
sh_type = 0x00000001
sh_flags = 0x00000006
sh_addr = 0x80008000
sh_offset = 0x00000060
sh_size = 0x00BE5550
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000002
to image_info section 0x00000001
sh_name = 0x00000021
sh_flags = 0x00000002
sh_addr = 0x80BED550
sh_offset = 0x00BE55B0
sh_size = 0x003599E0
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000004
to image_info section 0x00000002
sh_name = 0x00000031
sh_flags = 0x00000003
sh_addr = 0x80F46F30
sh_offset = 0x00F3EF90
sh_size = 0x00181FF0
Setting up to copy ELF section 0x00000005
to image_info section 0x00000003
sh_name = 0x00000037
sh_addr = 0x810C8F20
sh_offset = 0x010C0F80
sh_size = 0x00000010
sh_addralign = 0x00000004
sh_entsize = 0x00000004
Setting up to copy ELF section 0x00000006
to image_info section 0x00000004
sh_name = 0x0000003C
sh_addr = 0x810C8F30
sh_offset = 0x010C0F90
sh_size = 0x000002CC
cpu type : 0x00000033
image_info.entry_point = 0x80008000
image_info.section_count = 0x00000005
image_info.monstack = 0x800063EC
image_info.monra = 0x00000000
image_info.param0 = 0x00000002
image_info.param1 = 0x00000000
image_info.param2 = 0x00000000
image_info.param3 = 0x00000000
Section Index = 0x00000000
source = 0x800346BC
dest = 0x80008000
bytes = 0x00BE5550
Section Index = 0x00000001
source = 0x80C19C0C
dest = 0x80BED550
bytes = 0x003599E0
Section Index = 0x00000002
source = 0x80F735EC
dest = 0x80F46F30
bytes = 0x00181FF0
Section Index = 0x00000003
source = 0x810F55DC
dest = 0x810C8F20
bytes = 0x00000010
Section Index = 0x00000004
source = 0x810F55EC
dest = 0x810C8F30
bytes = 0x000002CC
cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 4K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Sizing flash
Exiting init
C1700 platform with 32768 Kbytes of main memory
rommon 2 > boot flash:c1710-k9o3sy-mz.122-4.YA2.bin
monra : 0x00000000
edata : 0x8000C0D0
magic : 0xFEEDFACE
source = 0x800346BC
dest = 0x80008000
bytes = 0x00BE5550
source = 0x80C19C0C
dest = 0x80BED550
bytes = 0x003599E0
source = 0x80F735EC
dest = 0x80F46F30
bytes = 0x00181FF0
source = 0x810F55DC
dest = 0x810C8F20
bytes = 0x00000010
source = 0x810F55EC
dest = 0x810C8F30
bytes = 0x000002CC
cisco Systems, Inc.
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
rommon 1 >
rommon 1 > meminfo
Main memory size: 32 MB.
Available main memory starts at 0x10000, size 32704KB
IO (packet) memory size: 5 percent of main memory.
NVRAM size: 32KB
rommon 2 > set
Re: flash memory issue - cisco 1710 - how do i erase flash memor
I think your choices are limited if your image isn't valid/no memory.
To tftp:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1700swcg/rom_mon.htm
To xmodem:
http://www.cisco.com/warp/public/130/xmodem_generic.html
Alternative is to put more memory into the 1700.
Steve
hi,
thx - i know - i've done all that ... this is way it's strange.
- i have the right image - from the site - checked md5
- going through all steps
- the memory is there - flash and RAM
- nothing is wrong with the hardware
- the router keeps saying the same thing
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
rommon 1 >
rommon 1 > meminfo
NVRAM size: 32KB
rommon 2 > set
Is it possible for the flash content to be altered ... i mean ... maybe the router did not erased the flash ... yes ... something is strange ... i don't remember the box asking me to erase the flash after the copy tftp flash: command .... ??!!!
The closest bug I could find was CSCdx56283. A TAC case would be your best bet.
Steve
394
