Community Member
Flow Control Command
what does the "Flow Copntrol" command do in switch 3550?
Thanks a lot
reza
1 REPLY
VIP Purple
Re: Flow Control Command
Hello Reza,
happy new year.
Basically. flow control is a mechanism that enables congestion control between two connected Ethernet ports. If a port cannot receive any more traffic, with flow control enabled, it would send a pause frame to the device at the remote end, effectively telling the remote device to stop sending frames.
Does that make sense ?
Check this link for a more detailed explanation:
Configuring IEEE 802.3z Flow Control
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225sec/3550scg/swint.htm#wp1138321
GP
1216
