flow-control is XOFF in GEIP+
hi,
Does anyone see the information and tell me the meaning ?
best regards.
fred.
TPE7513-1#show int gigabitEthernet 4/0/0
GigabitEthernet4/0/0 is up, line protocol is up
Hardware is cyBus GigabitEthernet Interface, address is 0010.0da4.6880 (bia 0010.0da4.6880)
Internet address is 210.243.127.1/28
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 23/255, rxload 32/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX
output flow-control is XOFF, input flow-control is XOFF
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:03:49
Input queue: 0/200/515/7038 (size/max/drops/flushes); Total output drops: 48556
Queueing strategy: fifo
Output queue: 0/200 (size/max)
30 second input rate 128026000 bits/sec, 28162 packets/sec
30 second output rate 90947000 bits/sec, 31609 packets/sec
197000194 packets input, 629065556 bytes, 0 no buffer
Received 17362 broadcasts, 0 runts, 0 giants, 4 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 5 ignored
0 watchdog, 0 multicast, 0 pause input
221516729 packets output, 3267334097 bytes, 0 underruns
4 lost carrier, 0 no carrier, 0 pause output
1 REPLY
Silver
Re: flow-control is XOFF in GEIP+
If you mentioned about the info in between lines, that has got to do with flow-controll, shows to be off....
133
