Community Member
For Multlink interface ,MTU size is set to 1500,but able to ping upto 9000.How???
Multilink is bundle of 2 E1 in chanellized STM-1
Hi,is the DF flag set?
is the DF flag set?
-Jonathan
Community Member
Thanks JonOn Multilink ,
Thanks Jon
On Multilink , fragment is disable....
Is this is the reason ???/
Ah not sure - just to verify,
Ah not sure - just to verify, are you setting the DF bit on your ping and testing that way?
-Jonathan
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, that's a PPP option.
As Jonathan has asked, are you setting DF in your ping?  If not, ping will allow larger than MTU, it will just fragment the IP packet.
Community Member
Hi Josheph , How PPP is
Hi Josheph , How PPP is support for Jumbo ping....?
Super Bronze
Disclaimer
Posting
It's not PPP, it's IP that does.
Again, try setting DF and see if it works.
However, if you're just ping across the PPP link, often serial media used with PPP supports MTUs larger than Ethernet.
79
