Forcing a traceroute after dial up connection
Is there a way to force a 1603 to do a specific traceroute and record the results in syslog after it has established a dial up ISDN connection?
Re: Forcing a traceroute after dial up connection
Trace only displays to the screen. You’ll have to capture & log your terminal/telnet session.
Many thanks your response, I was looking to see if there is an automated way rather than having to manually log on to the router. Maybe there isn't.....
If you were thinkig something like "macro" or some "script" that will do the job of the tracer, I dont thiks so. I havent heard of anything like that what is integrated within Cisco IOS that will do the job, I think that you'll have to trigger it from somewhere else and just record it in a syslog
Velimir
try checking the Service assurance agent (SAA): it enables a router to send out test packets that can measure a variety of network parameters such as round-trip delay, packet loss, and jitter. Multiple response time reporters (RTR) can be setup on a router, and each RTR can measure a different network performance parameter.
you can find info regarding SAA at the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_c/fcfprt3/fcf017.htm
Hope this helps
Ciao :-)
139
