Community Member
Forwarding Multicast with TTL=1
Dear group,
I am currently having a project of placing a 2621 on a customer's multicast network. However, the source came from their network is configured to have TTL=1 which the router will not forward these packets. Customer refused to change TTL on their application level, so is there any way I can get rid of this TTL=1 limitation to the router so that I can forward multicast out?
Community Member
Re: Forwarding Multicast with TTL=1
I looked all over what multicast doc I had, just about everything pointed to the fact that the app
sets the ttl. have you run this by the TAC yet?
Community Member
After going through all the docs around and had a conversation with Cisco engineer, I am pretty sure this is not doable on a router. Therefore I try to modify the solution into a L2 device, like a 3550-12T using VACL for simple packet filtering. This is somewhat very contradicting (as per customer's request) that they want a L3+ firewall but need a pure L2 device for not interrupting multicase.
333
